[Qgis-community-team] User Guide chapter 7 questions.
Ramon Andinach
custard at westnet.com.au
Thu Apr 21 08:24:25 EDT 2011
Evening all,
I've just committed and an updated working_with_projections. If anyone can have a look and provide some feedback, I'd be appreciative.
Tim, thanks for the answers. Would you be able to have a quick check and let me know if I'm misrepresenting the CRS sourcing?
Q2. Done.
Q3. I found the new icon (geographic.png) in default and copied it into images. But, svn didn't seem to notice and I don't think it uploaded.
Is it possible for someone to directly put geographic.png into images? (otherwise things might look a bit odd).
-ramon.
On 21/04/2011, at 15:34 , Tim Sutton wrote:
> Hi
> On Wed, Apr 20, 2011 at 5:26 PM, Ramon Andinach <custard at westnet.com.au> wrote:
>> Hi all,
>> Starting to work through my chapter, and have a few chapter specific questions.
>> 1. Is the source for QGIS's projection database still EPSG, via Post GIS (section 7.1)?
> In 1.7 the CRS db was regenerated using the GDAL gcs.csv and pcs.csv
> files (via the gdal utility script epsg_tr.py and the IGNF
> (http://trac.osgeo.org/qgis/ticket/3394) crs listing.
>> 2. The dialog boxes in the figures have had cosmetic alterations (mostly little images with the tabs). Is it worth updating them?
> Yes it will be great to update them if possible.
>> 3. There are many references to a projector icon. I saw that particular icon today when I fired up 1.6 for the first time in a while, but none of the 1.7 installs that I have to hand use that icon. Further I can't see the right icon (a grey thing that might be a stylised globe) in the images folder. What's best to do here?
> It was updated in 1.7. Once again it will be great to update them if
> possible. Actually we really need to come up with a system to automate
> taking screenshots. I believe we could probably write a little app to
> do it - and it would mean we can produce localised versions of the
> screenshots too.....something for the todo list I guess....
> Regards
> Tim
More information about the Qgis-community-team
