[Qgis-community-team] web/doc site structure
Otto Dassau
dassau at gbd-consult.de
Tue Nov 20 08:21:50 PST 2012
Hi Richard,
Am Tue, 20 Nov 2012 09:17:06 +0100
schrieb Richard Duivenvoorde <richard at duif.net>:
> Hi,
> currently it is messy at documentation.qgis.org
> there are actually two versions currently available there:
> http://documentation.qgis.org
> will point you to
> http://documentation.qgis.org/html/en/user_manual/
> which is in my point of view obsolete (it is an old version!)
> This should be the starting point
I changed that
> I have been trying to create a tree with two stems:
> docs
> website
> But this broke the poodle stuff (I think). I do not have access to the
> server, so I cannot fix it myself.
> The situation where we have the idea that we can both use poodle (with
> very short commit/push actions) and working via github/po files for
> translation will probably fail because of the git-conflicts that are
> likely to occur.
> I've been fighting with the automatic table of contents (TOC) creation
> of Sphinx. The stuff you see in the left bar is actually sphinx
> generated. I wanted it to be a logical 'menu' like toc, but I think I
> failed.
> So please help or give some input to decide:
> - is the division in docs/website nessecary or only bloat (we can easily
> go back to the version without website stuff)
I don't know from translation side but would prefere to have it divided as
you did.
> - should we decide for ONE translation process (eg only poodle, because
> you need the least technical knowledge (as a translator))
you mean one web and one desktop way or only web based? If yes, I would
support it. but we should have the possibility to work on the translation
locally as well.
> - should we create the menu stuff in the left bar ourselves (by
> generating a truly tree like structure in which we give every node their
> own menu.html)
what is the advantage? Why do we need it?
> - Paolo's point about being en-centric is very valid, please think with
> us about a solution to for example start with a russian or spanisch help
> text for a doc (IF this is possible)
this is an interesting point but at the moment I also don't have a solution
how to solve this. I guess for now we need to stick to english and add all
foreign tutorials to the wiki and keep the idea in mind.
> - we need a tree structure in which we then also can house little help
> articles like the person in Paolo's mail was mentioning
also a good idea, if someone has an idea how to do it.
> - why is the documentation not rebuild every day (crontab is failing?)
I will test/fix it
> I still fully support the sphinx/rst model, but we need some more love
> to put in it to get this thing running.
yes, i agree and man power, of course. There are many nice ideas but we
don't have enough people for all these ideas at the moment. A few people
started with the documentation/translation, now we extended it to create a
new web. That's fine, but we should concentrate on these two topics for now,
collect the ideas/tasks in the wiki and work on it later.
I hope more people will find time to help and join the discussion and
work ..., but I also know it is not that easy, because quite deep knowledge
of rst/sphinx/... is necessary.
Anyway thanks a lot Richard and all others for your effort so far!
Regards
Otto
> Regards,
More information about the Qgis-community-team
