[Qgis-community-team] line breaks in rst-tables
Richard Duivenvoorde
rdmailings at duif.net
Fri May 10 07:15:50 PDT 2013
Hi Larissa,
I've been playing with it in the 'ReText' editor. In that gui-editor you
have a sort of a direct html preview (I did not try latex)
I was able to insert linebreaks in table cells using pipe symbols (
found it here:
http://people.ee.ethz.ch/~creller/web/tricks/reST.html#simple-tables )
Menu option Shortcut Reference Toolbar
text text text | four
| rows
| of
| text in 1 cell
text | text in
| one cell
text
BUT NEVER in the first column. I did a of of trials...
(here http://wiki.typo3.org/ReST_Syntax they mention that you cannot
have linebreaks in the first ROW...)
Docs say that if you want more complex tables you should not use
'simple-tables' :-(
So maybe you could either change the order of the columns??
Or create a fake (number like) column in front?
n Menu option Shortcut Reference Toolbar
1 | text text text text text text
| text
2 | this and text
| that
3 text
4 text | blah blah
5 | blah blah
| blah
| blah blah
I think by now YOU are the rst wizard of our team :-)
Regards,
Richard
On 10-05-13 12:37, Larissa Junek wrote:
> Hi all,
> we use simple tables in the qgis user manual. how can we force rst to
> make line breaks in a table? In the user manual so far line breaks
> sometimes work and sometimes don't. What exactly should I consider so
> that rst makes a line break?
> Here's the table structure:
> text text text text text text text text text
> text
> text
> E.g. in the text in Toolbar should be inserted a line break which
> appears in the output documents like HTML and PDF.
> Kind regards,
> Larissa
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
