[Qgis-community-team] line breaks in rst-tables
Diethard Jansen diethard.jansen at gmail.com
Fri May 10 12:34:17 PDT 2013
Hi Larissa,
I like the simple tables and if you look in substitutions.rst you can see
that what you have to do, is to make sure that for every cel you provide an
entry (press the *[raw]* button to see the ReST code). For empty cells use
the escape character ('\') followed by a space. So the last character of
every line that seems to end with an escape character really ends with a
space!
Regards,
Diethard.
2013/5/10 Larissa Junek <junek at gbd-consult.de>
> Hi all,
> we use simple tables in the qgis user manual. how can we force rst to
> make line breaks in a table? In the user manual so far line breaks
> sometimes work and sometimes don't. What exactly should I consider so
> that rst makes a line break?
> Here's the table structure:
> Menu option  Shortcut    Reference   Toolbar
> text         text        text        text text text text text text
> text
> text
> E.g. in the text in Toolbar should be inserted a line break which
> appears in the output documents like HTML and PDF.
> Kind regards,
> Larissa
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130510/7aa68ffb/attachment.html>
More information about the Qgis-community-team mailing list
