[Qgis-community-team] line breaks in rst-tables
Diethard Jansen
diethard.jansen at gmail.com
Sat May 11 01:06:42 PDT 2013
I did not provide a good link to
substitutions.rst<https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/documentation_guidelines/substitutions.rst>.
This one works..
Regards,
Diethard
2013/5/10 Diethard Jansen <diethard.jansen at gmail.com>
> Hi Larissa,
> I like the simple tables and if you look in substitutions.rst you can see
> that what you have to do, is to make sure that for every cel you provide an
> entry (press the *[raw]* button to see the ReST code). For empty cells
> use the escape character ('\') followed by a space. So the last character
> of every line that seems to end with an escape character really ends with a
> space!
> Regards,
> Diethard.
> 2013/5/10 Larissa Junek <junek at gbd-consult.de>
>> Hi all,
>> we use simple tables in the qgis user manual. how can we force rst to
>> make line breaks in a table? In the user manual so far line breaks
>> sometimes work and sometimes don't. What exactly should I consider so
>> that rst makes a line break?
>> Here's the table structure:
>> Menu option Shortcut Reference Toolbar
>> text text text text text text text text text
>> text
>> text
>> E.g. in the text in Toolbar should be inserted a line break which
>> appears in the output documents like HTML and PDF.
>> Kind regards,
>> Larissa
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130511/0b3f1f9d/attachment.html>
More information about the Qgis-community-team
