[Qgis-community-team] line breaks in rst-tables
Otto Dassau dassau at gbd-consult.de
Sat May 11 06:07:09 PDT 2013
Hi Larissa,
another simple solution might also be to change the translations of the
headlines, that are used as reference :ref For example in the german
translation the tables in inroduction/qgis_gui.po sometimes include long
headlines as :ref: paramete. If you shorten the headline translation, it also
reduces the table width.
hope this helps as well.
Regards
Otto
Am Fri, 10 May 2013 12:37:25 +0200
schrieb Larissa Junek <junek at gbd-consult.de>:
> Hi all,
> we use simple tables in the qgis user manual. how can we force rst to
> make line breaks in a table? In the user manual so far line breaks
> sometimes work and sometimes don't. What exactly should I consider so
> that rst makes a line break?
> Here's the table structure:
> Menu option  Shortcut    Reference   Toolbar
> text         text        text        text text text text text text
> text
> text
> E.g. in the text in Toolbar should be inserted a line break which
> appears in the output documents like HTML and PDF.
> Kind regards,
> Larissa
More information about the Qgis-community-team mailing list
