[Qgis-community-team] change usage of index
Diethard Jansen
diethard.jansen at gmail.com
Mon May 13 13:27:19 PDT 2013
Hi Otto,
I agree that if those indexes (hidden from translator) include words that
need translation they should be removed from those indexes.
I added a few of those indexes that are placed before each section. However
I took care that it did not include words that needed translation (I
thought). So they include standarised terms like WMS, WFS, DXF, AutoCad
etc..
The big advantage is that jumping to a declared index before a section
brings you really to that section. If you use an inline index declared in
the text you will overshoot and end up below the text where the index was
actually declared. The problem is a bit bigger with current theme.
Regards,
Diethard.
2013/5/12 Otto Dassau <dassau at gbd-consult.de>
> Hi
> for the manual we also create an index, which is nice, but can not be used
> by linguist for translation at the moment, if we do it this way.
> .. index:: WMS, WFS, WCS, CAT, SFS, GML
> Instead I would suggest, that for the future (in master) we integrate the
> index syntax into the text, so it can be translated as well, like in this
> example.
> Two interesting :index:`actions` are shown below...
> Hope this ok and I would like to ask, if someone would be able to spend
> some
> time and go through the current master document of the user manual and
> change all index syntax. Please send an email to the list, so we can
> organize it.
> btw: I changed this in the documentation_guidelines/README.rst file.
> Regards
> Otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130513/91228b15/attachment.html>
More information about the Qgis-community-team
