[Qgis-community-team] Any .ts file for Hindi translation of GUI
Werner Macho werner.macho at gmail.com
Fri Nov 1 06:48:22 PDT 2013
Hi Harish!
Basically I have no idea about the fonts to be used .. We heavily rely
on what the system supports. As a native speaker you might know it
better what the languages are written in and how the font should look
like ..
Try it - and if it does not work (because Qt or linguist does not
support it) you might have to change to other options you have.
For the second question:
<p>Character: <span style="font-size: 24pt; font-family:
%1">%2</span><p>Value: 0x%3 and "&"
Don' translate anything which is encapsulated by < and > but
everything outside can be translated:
So in this case you might translate
Character: and
Value:
everything inside <> is indeed a command for the computer (in this case HTML)
Thanks a lot for your help
kind regards
Werner
On Fri, Nov 1, 2013 at 3:43 PM, Harish <harry.om2000 at gmail.com> wrote:
> I have got the work started on Hindi GUI translation, using .ts file. Some
> guidance is required.
> 1) In my system (windows7, 32 bit) it is showing only two languages of Hindi
> for keyboard. One is Devnagari INSCRIPT and other is Hindi Traditional which
> is showing as 'Mangal' in font's list in word doc. The same font is shown
> for Google translated text also. Do we have to be limited to these only or
> we have control over fonts to be used?
> 2) What to translate out of <p>Character: <span style="font-size: 24pt;
> font-family: %1">%2</span><p>Value: 0x%3 and "&" etc
> words/strings/characters? I feel these are related to programming and should
> remain intact.
> Regards
> On Wed, Oct 2, 2013 at 4:06 PM, Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> On 02-10-13 11:29, Werner Macho wrote:
>> > Created the qgis_hi.ts file for GUI translation .. so everything is
>> > now prepared to start for hindi language ..
>> > 20 days is probably a bit too less for GUI .. considering the amount
>> > of currently 10157 strings ..
>> > Good to see a new language coming up ..
>> Nice, Thanks Werner!
>> So Harish:
>> the ts is here:
>> https://github.com/qgis/QGIS/blob/master/i18n/qgis_hi.ts
>> download the 'raw version':
>> https://github.com/qgis/QGIS/blob/master/i18n/qgis_hi.ts?raw=true
>> load it in Linguist, start translating, and sent periodically to Werner
>> Regards,
More information about the Qgis-community-team mailing list
