[Qgis-community-team] translation question
Werner Macho
werner.macho at gmail.com
Thu May 22 06:03:24 PDT 2014
Hi Otto!
If there is one single file containing the source you can upload it by
more or less a trick ..
Download the original translation file of that file - rename your
translation after that file and upload the translation again ..
at least this trick worked for me with one file ..
bad luck if it is splitted into tons of files - too much work to do it
that way than..
regards
Werner
On Thu, May 22, 2014 at 3:01 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi Richard,
> we have an old translation from QGIS manual 1.8 (the GPL and FDL appendix)
> and this translation is not in transifex. Probably, because it was not
> translated with transifex at that time.
> Is it possible to just upload the 1.8 .po files to transifex? Would that
> work? I remember it would not be recognized correctly?
> Regards
> Otto
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
