[Qgis-community-team] 'translate' deep links sometimes successfull, sometimes failing
Richard Duivenvoorde
richard at duif.net
Mon Jun 29 07:47:43 PDT 2015
Hi Elena,
thanks!! you brought me on the right track. I did not see these
differences in the slugs...
So this is actually a issue with my code that creates the wrong
transifex links! I have fixed it and after the next build (tomorrow or
later) this should be working again.
Please start not 'fixing' wrong uri's, it is better to fail then to get
redirected to a place where you think we should go...
As said, it was simply my code which created a wrong resource uri
FYI: we create the resources/uri's for .tx/config with this script:
https://github.com/qgis/QGIS-Website/blob/master/scripts/create_transifex_resources.sh#L38
And we have some javascript magic in the pages which create the
transifex uri's based on current url:
https://github.com/qgis/QGIS-Website/blob/master/themes/qgis-theme/languageswitch.html#L65
Thanks for the help!
Regards,
On 29-06-15 14:27, Transifex Support wrote:
> Hello Richard,
> Thank you very much for your thorough reply.
> Please note that we further investigated the case with the engineering
> team and we noticed that there are several underscores in the links that
> don't work, that there should have been dashes instead (image
> <https://s3-eu-west-1.amazonaws.com/uploads-eu.hipchat.com/30169/205243/gPZcpI8Jlp8Z6Vn/Screen%20Shot%202015-06-29%20at%202.35.03%20PM.png>).
> Also note that the name you used was already "slug-compatible", so our
> "slugger" didn't have to replace anything and it's odd that the issue
> you mentioned occured.
> In any case, as long as you type it correctly it should work. Still,
> we're going to check if there's an option to automatically replace this
> kind of "typos".
> I hope this helps, but if after replacing the erroneous links you
> encounter another similar issue, please let us know.
> Feel free to ask me any further questions that you might have.
> Best,
> Elena
> How would you rate my reply?
> Satisfaction Rating Icons
> Elena Kazia Batma
> On Thu, Jun 25, 2015 at 10:58 AM PDT, Richard Duivenvoorde
> <richard at duif.net> wrote:
>> Hello Richard,
>> > Thank you for using Transifex and for submitting your request.
>> > Please note that as long as one copies and pastes the link as provided
>> > by Transifex it will for sure work. For me, even links that you
>> > mentioned that they have stopped loading, have worked.
>> > Still, I suppose that you actually need to address these issues to the
>> > site that provides you with the "erroneous" links, since it doesn't seem
>> > to be something wrong on our end.
>> Hi Elena,
>> thanks for your response, but well, I'm the builder of the code of the
>> site myself :-)
>> and I craft these url's by looking into the url's that transifex uses
>> theirselves...
>> and indeed this one is now working (now):
>> https://www.transifex.com/projects/p/qgis-website/translate/#da/site_forusers_commercial_support
>> but this one still isn't (for me):
>> https://www.transifex.com/projects/p/qgis-documentation/translate/#de/docs_user_manual_plugins_plugins_road_graph
>> and every page in our docs (eg the german translation:
>> http://docs.qgis.org/2.8/de) == a resource, and most of them do not work
>> or sometime do not work.
>> my gut-feeling is that there is somewhere in the
>> caching/redirecting/url-rewriting process sometimes things go wrong :-(
>> Regards,
>> On Thu, Jun 25, 2015 at 8:07 AM PDT, Transifex Support
>> <support at transifex.com> wrote:
>>> Hello Richard,
>>> provided by Transifex it will for sure work. For me, even links that
>>> you mentioned that they have stopped loading, have worked.
>>> the site that provides you with the "erroneous" links, since it
>>> doesn't seem to be something wrong on our end.
>>> I hope I shed some light on the issue, but if this is not the case,
>>> please let me know how I could further assist you.
>>> Kind regards,
>>> Elena
>>> Elena Kazia Batma
>>> On Sun, Jun 21, 2015 at 11:56 PM PDT, Richard Duivenvoorde
>>>> Hi,
>>>> our project site and docs are translated using transifex:
>>>> http://qgis.org
>>>> To make it easier for translators to locate the resource to translate,
>>>> we thought to add a 'deep link' to the translatable resource in
>>>> Transifex.
>>>> But different pages, and subdomains are sometimes working and
>>>> sometimes not:
>>>> WORKING:
>>>> http://qgis.org/da/site/forusers/support.html
>>>> in the footer is a link to:
>>>> https://www.transifex.com/projects/p/qgis-website/translate/#da/site_forusers_support
>>>> which for me (when I'm logged in) is redirected to:
>>>> https://www.transifex.com/projects/p/qgis-website/translate/#da/site_forusers_support/17318283
>>>> the right resource!
>>>> NOT WORKING:
>>>> http://qgis.org/da/site/forusers/commercial_support.html
>>>> has a link:
>>>> which redirects to
>>>> https://www.transifex.com/projects/p/qgis-website/translate/#da/$/17318208
>>>> ending on a page with a 'loading' image, nog showing any resource
>>>> while searching for it in the (danish) resources, you wil end up here:
>>>> https://www.transifex.com/projects/p/qgis-website/translate/#da/site_forusers_commercial-support/17318305
>>>> Another example:
>>>> http://docs.qgis.org/2.8/de/docs/user_manual/plugins/plugins_road_graph.html
>>>> https://www.transifex.com/projects/p/qgis-documentation/translate/#de/$
>>>> I've build this a couple of months ago, and to my knowledge it was
>>>> working. At least for rst files, not the index files, which all are in
>>>> the 'sphinx' resource...
>>>> Anyway: my question:
>>>> is deeplinking allowed, and should this work?
>>>> if so: any idea why it is sometimes working and sometimes not
>>>> or is there another alternative to be helpfull to translators to
>>>> find the right resource if they want to fix something
>>>> Help is much appreciated,
>>>> Regards,
>>>> PS: in transifex I was redirected to a github issue tracker, and I even
>>>> created an issue in it:
>>>> https://github.com/transifex/transifex/issues/342
>>>> But apparently this project/issuetracker is not used anymore? Maybe
>>>> better to remove links to it in current transifex.com?
> {#HS:99378987-6063#}
More information about the Qgis-community-team
