[Qgis-community-team] QGIS docs: Vanilla build & ReadTheDocs theme
Alexandre Neto
senhor.neto at gmail.com
Fri Mar 15 13:44:02 PDT 2019
Thanks!!
I will definitely check it out.
Thanks for the work.
Alex
A sex, 15/03/2019, 20:03, Richard Duivenvoorde <rdmailings at duif.net>
escreveu:
> For those interested,
> We've been playing around with a more vanilla use of Sphinx to build the
> documentation:
> 1) because the transifex (and hopefull Github) integration should be
> better now with newer Sphinx (not ready yet)
> 2) to make it possible for EVERYBODY to build the docs on both Windows,
> Linux (and probably also Macs) by creating an Python virtual env and run
> the default Sphinx make/bat file
> 3) because the vanilla ReadTheDocs theme is responsive.
> If you want to test, I made a little pet-project:
> https://github.com/rduivenvoorde/qgisdoc
> With a very small subset of the manual, so a quick build.
> I also did a full (english) build and uploaded here:
> https://qgis.org/test/en/
> Still need some styling stuff and work to make it possible to switch
> between versions and languages.
> Not sure if I want to do the pdf generation again, but we could if we
> want (as on the source nothing has changed).
> All this to give nobody an excuse to build and write documentation :-)
> Regards & let us know what you think,
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190315/a02e1c28/attachment.html>
More information about the Qgis-community-team
