[Qgis-community-team] QGIS docs: Vanilla build & ReadTheDocs theme
DelazJ
delazj at gmail.com
Mon Mar 18 00:05:42 PDT 2019
Hi Richard,
Thanks for your testing. I really like it and after years it visually
refreshes our documentation.
I have some issues I don't know whether I should raise them in the doc repo
or here.
Here they are:
- The |updatedisclaimer| does not seem to be substituted
- I think we should better set the margin in the TOC (the local content
one) between two different levels: see eg, spacing between "Symbology
properties" and "Band rendering" and same between the latter and "Multiband
color" at
https://qgis.org/test/en/docs/user_manual/working_with_raster/raster_properties.html
I think we should either keep the same space or reduce it as we go into
details, ie distance "Sources properties <-> Symbology properties" >=
"Symbology properties <-> Band rendering" which is >= "band rendering <->
"Multiband color"
- Still in the above page, it could be nice to have some spacing between
the "path" and the "View page source" button
- I like in the left panel the display of the sections of the chapter
current chapter (a long standing issue report in the repo) and the
highlighting of the active section. I also like this frame being visible
all the time. However, I think it should be scrollable since if I'm eg at
https://qgis.org/test/en/docs/user_manual/working_with_vector/vector_properties.html#symbology-properties
there's no easy way I could get back to qgis gui chapter (at least on my
17" screen); the selected chapter was moved at the top of the unscrollable
area.
- While I like the general soft coloring of the docs, I'm a bit dubious on
the background coloring of Processing parameters and sub parameters (
https://qgis.org/test/en/docs/user_manual/processing_algs/qgis/networkanalysis.html).
Sorry, no proposal yet.
- Also it's hard imho to quickly identify the algorithms (where they start
or end); maybe should we have a bigger top marging for algorithm name. I
know I've always complained about how aerate is our Processing algs docs, a
bit of aeration on top of alg name wouldn't make me unhappy.
Once again, despite all the issues reported above, I really like the path
we are taking. Thanks to you.
Regards,
Harrissou
Le ven. 15 mars 2019 à 21:44, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Thanks!!
> I will definitely check it out.
> Thanks for the work.
> Alex
> A sex, 15/03/2019, 20:03, Richard Duivenvoorde <rdmailings at duif.net>
> escreveu:
>> For those interested,
>> We've been playing around with a more vanilla use of Sphinx to build the
>> documentation:
>> 1) because the transifex (and hopefull Github) integration should be
>> better now with newer Sphinx (not ready yet)
>> 2) to make it possible for EVERYBODY to build the docs on both Windows,
>> Linux (and probably also Macs) by creating an Python virtual env and run
>> the default Sphinx make/bat file
>> 3) because the vanilla ReadTheDocs theme is responsive.
>> If you want to test, I made a little pet-project:
>> https://github.com/rduivenvoorde/qgisdoc
>> With a very small subset of the manual, so a quick build.
>> I also did a full (english) build and uploaded here:
>> Still need some styling stuff and work to make it possible to switch
>> between versions and languages.
>> Not sure if I want to do the pdf generation again, but we could if we
>> want (as on the source nothing has changed).
>> All this to give nobody an excuse to build and write documentation :-)
>> Regards & let us know what you think,
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190318/e9fc2560/attachment.html>
More information about the Qgis-community-team
