[Qgis-community-team] Report of QGIS documentation meeting
DelazJ delazj at gmail.com
Sat Mar 23 13:21:53 PDT 2019
Le sam. 23 mars 2019 à 16:54, Richard Duivenvoorde <rdmailings at duif.net> a
écrit :
> Thanks Alexandre,
> So now we can start theming :-) ...
> BUT BUT... what if we make it our goals to
> -4- use common images (in static/common) folder with relative paths.
> This would make that we do not need to (cannot) use the search-replace
> script, and as can use sources/static/common as img folder, git*.com
> will show them. I 'think' this makes it easier for writers.
> If they add a common img, they just drop it in the source/static/common
> folder (no copying/linking needed) and try out the right relative link.
> Disadvantages: we have to instruct to use the width/height attribute (in
> em units) and use common images as much as possible.
> Maybe do I misunderstand the point 4 but isn't it already the case (at
least from a goal perspective - for technical details I don't know)?
Common images (icons) as well as screenshots are available in source file
preview in github [0]
See also [1] [2] for the implementation details.
[0]
https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/user_manual/working_with_vector/vector_properties.rst
[1] https://github.com/qgis/QGIS-Documentation/pull/2301
[2]
https://docs.qgis.org/3.4/en/docs/documentation_guidelines/writing.html#figures-and-images
Regards,
Harrissou
Please have a look at github pages and gitlab pages below, and build
> yourself to see what it looks now. Also play with source.conf options if
> you want.
> Also feel free to disagree :-)
> Regards,
> [0] https://github.com/rduivenvoorde/qgisdoc/
> [1] https://gitlab.com/rduivenvoorde/qgisdoc/
> [3]
> https://gitlab.com/rduivenvoorde/qgisdoc/blob/master/source/docs/user_manual/trans.rst
> [4]
> https://gitub.com/rduivenvoorde/qgisdoc/blob/master/source/docs/user_manual/trans.rst
> On 23/03/2019 01.39, Alexandre Neto wrote:
> > Hi all,
> > I just created a rtd_qgis theme based Read the Docs and used it in the
> > conf.py. I believe this is the way we should customize RTD themes
> > without disrupting it. I haven't done it, but we can also replace HTML
> > files to add stuff like the language selector somewhere.
> > https://github.com/rduivenvoorde/qgisdoc/pull/3
> > This is what I have used for inspiration:
> > https://www.sphinx-doc.org/en/master/theming.html
> https://sphinx-rtd-theme.readthedocs.io/en/stable/configuring.html#theme-options
> > Cheers,
> > Alex Neto
> > Alexandre Neto <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>>
> > escreveu no dia sexta, 22/03/2019 às 20:01:
> >     Hi!
> >     Sorry for such a short presence, I though the meeting was set to
> GMT...
> >     I would like to follow up the sphinx-theme customization. I will
> >     study the sphinx way of nesting theme so we can alway update the
> >     read the docs theme and put our customization on top of it.
> >     Best regards,
> >     Alex
> >     A sex, 22/03/2019, 16:35, matteo <matteo.ghetta at gmail.com
> >     <mailto:matteo.ghetta at gmail.com>> escreveu:
> >         Hi all,
> >         here a brief summary of the meeting we had:
> >         * we will wait another week to push the translated resources of
> the
> >         documentation of 3.4. We are waiting for the new transifex-github
> >         integration method that should make things easier, but it seems
> >         hard to
> >         put it in production
> >         * get rid of the pdf documents but still provide downloadable
> >         resources
> >         for online use as html zip file (for every language). Reasons:
> pdf
> >         builder is not easy to maintain, heavy resources asking while
> >         with html
> >         we have the same builder (we just need to create the zip files)
> >         and html
> >         are usable offline together with QGIS (interactive links and
> >         help buttons)
> >         * change doc theme to vanilla-rdt. There are still some issues
> >         and fix
> >         to make, but we (thanks Richard) have already something online
> >         [0]. We
> >         will work from time to time to fix all the issues and then
> >         publish it
> >         * splitting the main repository into different ones (static vs
> >         dynamic)
> >         is not a priority for now. There seems not to be blockers with
> the
> >         current environment that works fine
> >         * we still have some redirection issues of the main website (3.0
> and
> >         3.4). If someone is wiling to help Richard with apache and/or
> >         Tudor with
> >         nginx is more than welcome
> >         * this meeting was a great success: I think it is the first
> >         documentation meeting of the QGIS history (?) so we thought that
> >         it is a
> >         good habit to do this "often" (every 2 months or of course every
> >         time is
> >         needed)
> >         Thanks to all the participants!
> >         Cheers
> >         Matteo
> >         [0] https://qgis.org/test/en/docs/index.html
> >         _______________________________________________
> >         Qgis-community-team mailing list for organizing community
> >         resources such as documentation, translation etc..
> >         Qgis-community-team at lists.osgeo.org
> >         <mailto:Qgis-community-team at lists.osgeo.org>
> >         https://lists.osgeo.org/mailman/listinfo/qgis-community-team
> >     Alexandre Neto
> >     @AlexNetoGeo
> >     http://sigsemgrilhetas.wordpress.com
> >     http://gisunchained.wordpress.com
> > Alexandre Neto
> > @AlexNetoGeo
> > Qgis-community-team mailing list for organizing community resources such
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190323/2b4eee6f/attachment.html>
More information about the Qgis-community-team mailing list
