[Qgis-community-team] make doctest with default installation
matteo matteo.ghetta at gmail.com
Mon May 27 03:30:39 PDT 2019
Hi Arnauld,
> Seems that the virtual environment exists, but does not contains pip.
that's weird..
> Try to remove folder "venv" and try again (it should create a new fresh
> one).
yep, working now, thanks!
BTW now I get a bunch of errors from the code snippet, like:
Application path not initialized
File "docs/pyqgis_developer_cookbook/crs.rst", line 71, in default
Failed example:
    # PostGIS SRID 4326 is allocated for WGS84
    crs = QgsCoordinateReferenceSystem(4326,
QgsCoordinateReferenceSystem.PostgisCrsId)
    assert crs.isValid()
Exception raised:
      File "/usr/lib/python3.7/doctest.py", line 1329, in __run
        compileflags, 1), test.globs)
      File "<doctest default[0]>", line 3, in <module>
    AssertionError
The snippet is correct (trying it in the python console of QGIS the
assert is valid), so I think something is going on with "Application
path not initialized"
Other magic suggestions :) ?
Thanks again
Matteo
More information about the Qgis-community-team mailing list
