[Qgis-community-team] make doctest with default installation
matteo
matteo.ghetta at gmail.com
Mon May 27 06:50:55 PDT 2019
Hi Arnauld,
> I suspect your QGIS_PREFIX_PATH is *NOT* properly configured.
something was stack somewhere (maybe in the cache I don't know), now is
working.
I'll ask you another thing related to the tests. With a simple test like:
.. testcode::
exp = QgsExpression('1 + 1 = 2')
.. testoutput::
assert(not exp.hasParserError())
I have local failing because of:
File "docs/pyqgis_developer_cookbook/expressions.rst", line 169, in default
Failed example:
Expected:
Got nothing
and actually it is right. Putting the code in the python console,
assert(not exp.hasParserError()) gives NO output.
Are better asserts to use (assertTrue or similar?). Just asking because
it would be nice to have a good testing framework.
Cheers and thanks
Matteo
More information about the Qgis-community-team
