[Qgis-community-team] [Writing-QGIS-Doc][Processing] Check Validity
João Gaspar joao.f.r.gaspar at gmail.com
Fri Oct 11 04:33:13 PDT 2019
Hi guys,
I'm adding section inside of the Check Validity that explains what kind of
error messages give and their meanings in
source>processing_algs>qgis>vectorgeometry.rst
The explanation will subdivide into two tables one for the GEOS method and
other to the QGIS method. So my idea is to have a table for each one with
the following headers:
Error Message | Explanation    | Example (probably an image)     |
Error 1              |Why is happen| Drawing or image map of the error |
Error 2              |Why is happen| Drawing or image map of the error |
Error 3             |Why is happen| Drawing or image map of the error |
Please see the QGIS-Developer list for all available options:
https://lists.osgeo.org/pipermail/qgis-developer/2019-September/058692.html
I'm writing to you if there is a commit or a need-docs label for this
algorithm to associate and put in my checkout name branch before doing the
work and the pull request.
Regards,
João aka James
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20191011/e263def0/attachment.html>
More information about the Qgis-community-team mailing list
