[Qgis-community-team] [Writing-QGIS-Doc][Processing] Check	Validity
    Alexandre Neto
    senhor.neto at gmail.com
    Fri Oct 11 04:54:02 PDT 2019
There's this ticket about check validity, not sure it's related to what you
propose to document or not, but while you are doing it, maybe you can
taggle this one as well.
https://github.com/qgis/QGIS-Documentation/issues/3492
BTW, no need to create a branch with a specific name, that's for your
organization only. So a branch called "explain_validity_check" would be
just fine.
Alex
On Fri, Oct 11, 2019 at 12:33 PM João Gaspar <joao.f.r.gaspar at gmail.com>
wrote:
> Hi guys,
> I'm adding section inside of the Check Validity that explains what kind of
> error messages give and their meanings in
> source>processing_algs>qgis>vectorgeometry.rst
> The explanation will subdivide into two tables one for the GEOS method and
> other to the QGIS method. So my idea is to have a table for each one with
> the following headers:
> Error Message | Explanation    | Example (probably an image)     |
> Error 1              |Why is happen| Drawing or image map of the error |
> Error 2              |Why is happen| Drawing or image map of the error |
> Error 3             |Why is happen| Drawing or image map of the error |
> Please see the QGIS-Developer list for all available options:
> https://lists.osgeo.org/pipermail/qgis-developer/2019-September/058692.html
> I'm writing to you if there is a commit or a need-docs label for this
> algorithm to associate and put in my checkout name branch before doing the
> work and the pull request.
> Regards,
> João aka James
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20191011/ddc8fda4/attachment.html>
More information about the Qgis-community-team
