[Qgis-developer] 0.8; here I go
Maciek Sieczka
werchowyna at epf.pl
Wed Apr 5 11:18:03 EDT 2006
On Wed, 5 Apr 2006 00:06:57 +0100
"Tim Sutton" <tim at linfiniti.com> wrote:
<snip>
> > At the _very_first_ run only, opening a project (File, Open project)
> > brings a file selector saying it's in my $HOME, but the folder is
> > entirely empty (the attached screendump). Going a DIR up and back
> > and my $HOME contents are displayed
> No idea what thats about...
More to it: it also happens at very first "Add a Vector layer" and "Add
a Raster Layer".
> > 2.
> > Settings, Project properties, Projection:
> > SRIDSs 172-175 (EPSG 2170-2174) declare "+proj=stere", while it
> > should be "sterea". Eg.:
> 8<-----------snip -------------
> > Maciek
> > Should I fill bug reports in Trac?
> Bug reports are good. Bug reports accompanied with fixes are even
> better! You will find under the svn checkout two sqlite.db files under
> qgis/resources
> qgis.db is the template for user database of srs's (its blank to start
> with for each user)
> srs.db is the system wide srs database.
> You are welcome to provide patches for the latter in the form of sql
> insert / update statements.
Sorry, I don't have enough time.
I'll take this bug for reported being mentioned here.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
