[Qgis-developer] Re: GRASS Unit Tests for Win Build
"Sören Gebbert"
soerengebbert at gmx.de
Mon Dec 11 17:54:07 EST 2006
Hi Tim,
i have tried to run the grass test suite within the msys environment.
But the tests failed for many modules, because the library
libgrass_gproj.6.3.cvs.dll was not found.
The test suite depends on g.region, g.remove, g.parser
and some other grass modules.
So the test suite is not fully independent from grass. :(
i.e: g.region is called for each unit and integration test.
Maybe this lib was not copied to the lib dir?
Best regards
Soeren
-------- Original-Nachricht --------
Datum: Mon, 11 Dec 2006 13:20:52 -0200
Von: "Tim Sutton" <tim at linfiniti.com>
An: "Sören Gebbert" <soerengebbert at gmx.de>
Betreff: GRASS Unit Tests for Win Build
> Hi Soren
> Could you run your unit tests again? Freddy build GRASS natively under
> msys and Ive included that in the currently available setup.exe
> snapshot build. It would be good to know if the issues are resolved
> there and if any new ones have taken their place.
> Regards
> Tim
> On 12/8/06, "Sören Gebbert" <soerengebbert at gmx.de> wrote:
> > Hi Tim,
> > thanks great work!
> > I have checked the grass modules with the grass-test-suite.
> > The result is available here:
> http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html_win32/
> > Here are some screenshots of the qgis-grass shell with some test-suite
> run results:
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/Qgis_0_8_Grass_6_3_Mingw_TestSuite_general_db.png
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/Qgis_0_8_Grass_6_3_Mingw_TestSuite_rast3d_vector.png
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/Qgis_0_8_Grass_6_3_Mingw_TestSuite_raster.png
> > Most of the modules are working well, only r3.info seems to have
> > problems with windows.
> > Best regards
> > Soeren
> > Datum: Fri, 8 Dec 2006 17:01:59 -0600
> > An: qgis-developer <qgis-developer at lists.qgis.org>, qgis-user
> <qgis-user at lists.qgis.org>
> > Betreff: [Qgis-developer] QGIS Windows Snapshot - with WMS and SPIT
> > > Hi
> > > I've uploaded a new snapshot of QGIS for windows with WMS raster
> > > support and SPIT plugint:
> > > http://qgis.org/uploadfiles/testbuilds/qgis_setup.exe
> > > Regards
> > > Tim Sutton
> > > Visit http://qgis.org for a great Open Source GIS
> > > Home Page: http://linfiniti.com
> > > Skype: timlinux
> > > MSN: tim_bdworld at msn.com
> > > Yahoo: tim_bdworld at yahoo.com
> > > Jabber: timlinux
> > > Irc: timlinux on #qgis at freenode.net
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.qgis.org
> > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > "Ein Herz für Kinder" - Ihre Spende hilft! Aktion:
> www.deutschlandsegelt.de
> > Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's
> Cup-Yacht!
> Tim Sutton
> Skype: timlinux
> Jabber: timlinux
"Ein Herz für Kinder" - Ihre Spende hilft! Aktion: www.deutschlandsegelt.de
Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's Cup-Yacht!
