[Qgis-developer] Re:  GRASS Unit Tests for Win Build
    Gary Sherman
    sherman at mrcc.com
    Mon Dec 11 18:11:34 EST 2006
On Dec 11, 2006, at 1:54 PM, Sören Gebbert wrote:
> i have tried to run the grass test suite within the msys environment.
> But the tests failed for many modules, because the library
> libgrass_gproj.6.3.cvs.dll was not found.
The library is in the top-level directory where qgis is installed
(this is true for the latest test build). Try adding your qgis
install directory to the path and then testing.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
"We work virtually everywhere"
