[Qgis-developer] compile qgis svn
Otto Dassau
otto.dassau at gmx.de
Mon Oct 16 09:03:08 EDT 2006
On Mon, 16 Oct 2006 12:48:01 +0200
"Martin Dobias" <wonder.sk at gmail.com> wrote:
> On 10/16/06, Otto Dassau <otto.dassau at gmx.de> wrote:
> > On Mon, 16 Oct 2006 12:10:49 +0200
> > > > Dear list,
> > > > I try to compile qgis from svn today on debian sarge with qt4.1.0 with
> > following
> > > > error:
> > > > /root/debian/qgis-0.8.0cvs/src/core/.libs/libqgis_core.so: undefined
> > > > reference to `y ytext'
> > > > undefined reference to `y ylex()'
> > > > reference to `s et_input_buffer(char const*)'
> > > > collect2: ld returned 1 exit status
> > > > make[5]: *** [qgis] Fehler 1
> > > > make[5]: Leaving directory `/root/debian/qgis-0.8.0cvs/src/gui'
> > > > make[4]: *** [install] Fehler 2
> > > > make[4]: Leaving directory `/root/debian/qgis-0.8.0cvs/src/gui'
> > > > does anybody has an idea, what this can be?
> > > Hi Otto,
> > > this is weird. It looks like files generated by flex/bison don't exist
> > > or have not been compiled. Could you check whether there are files
> > > qgssearchstringlexer.cpp and qgssearchstringparser.cpp in src/core
> > > directory?
> > Hi Martin,
> > they don't exist in src/core
> > ls ./debian/qgis-0.8.0cvs/src/core/qgssearchstring*
> > qgssearchstring.cpp
> > qgssearchstringlexer.ll
> > qgssearchstringparser.yy
> > qgssearchstring.h
> > qgssearchstringparser.cc
> > qgssearchstringlexer.cc
> > qgssearchstringparser.h
> My bad, their extension should be .cc. Can you take a look in
> src/core/.libs directory whether files
> libqgis_core_la-qgssearchstringlexer.o and
> libqgis_core_la-qgssearchstringparser.o exist?
no they don't exist
ls ./debian/qgis-0.8.0cvs/src/core/.libs/
libqgis_core.a libqgis_core.lai libqgis_core.so.0
libqgis_core.la libqgis_core.so libqgis_core.so.0.0.1
> If so, could post to
> some place those two generated .cc files so I can take a look if
> they're ok?
> Have you tried to do make distclean and then start building again?
> Is this first time you compile 0.8 from sources or you managed to
> build it earlier?
- yes, I used make distclean several times before.
- no, I haven't build a current svn source in this environment (debian sarge)
before, it is a new chroot installation. But I just tried to compile it under
debian etch and there is is no problem, so there is probably something missing
in my sarge installation, I guess.
thanks a lot
Otto
> Martin
> > thanks
> > Otto
> > > Martin
> > > > thanks a lot
> > > > Otto
> > > > _______________________________________________
> > > > Qgis-developer mailing list
> > > > Qgis-developer at lists.qgis.org
> > > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
