[Qgis-developer] QGIS 0.9.2 release plans (and new bug triage!)
Tim Sutton
tim at linfiniti.com
Fri Dec 7 11:16:15 EST 2007
Hi
I beleve that its just the new splitter Gavin or Steven added. Try to
look on the right of the window for a splitter bar and pull it over to
the left. I had the same problem when the changes first went into svn
and it was resolved by just pulling open the splitter bar.
Regards
Tim
2007/12/7, lami at faunalia.it <lami at faunalia.it>:
> > Hi All
> > QGIS 0.9.1 is tagged and only work to do really on it is packaging and
> > press releases which we are aiming to happen by Dec 10 2007 (early
> > next week).
> > Turning our release machine to 0.9.2 I want to keep the momentum and
> > reach my release nirvana of a minor point release every two or so
> > months. The 0.9.1 bug triage was a great success (70 bugs killed!) and
> > so I've started a new triage page for 0.9.2 here:
> > https://svn.qgis.org/trac/wiki/BugTriage0.9.2
> > There are still some low hanging fruit in the bug queue so it will be
> > really good to get rid of those first. I've also started a new release
> > checklist:
> > http://wiki.qgis.org/qgiswiki/ReleaseChecklist0.9.2
> > and bumped the version numbers and splash in trunk up to 0.9.2. Could
> > we hold another developers meeting next week to discuss plans for the
> > 0.9.2 release. Currently there seem to be the following possible
> > feature additions:
> > - raster transparency branch merge
> > - diagram branch merge
> > - advanced editing merge
> > - qml / default symbolisation (and some vector props dialog cleanups)
> > - Jürgen was wanting to make some changes to CMake (use only relative
> > paths for install prefixes)
> > - I would like to start going through the dialogs and addressing
> > consistency issues (label capitalisation and writing style, layout
> > consistency, reduce unneeded popups etc). I wont have time to go
> > through all dialogs, but I would like to start with the grass dialog
> > (I've posted some thoughts on this to the list last month).
> > - anything else?
> > No doubt not all of the things above will make it into 0.9.2 but it
> > would be good to get together and discuss what can / cant be done.
> > Regards
> Hi all,
> I made some test on this release and I see that the mapcomposer has some
> problems.
> I can see the function icons on the top, the help and close buttoms on the
> bottom but I can't see the layout area and the general and object menù.
> All the center area is grey. So I can't use the map composer.
> I see the same probelm in a little older Debian developer release.
> I thinked it was a developer versione but when I see that this problem is
> present also in this version I write about it.
> Any ideas about this problem?
> Regards
> Leonardo
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
