[Qgis-developer] extensions to postgis dialog
godofredo contreras
frdcn at hotmail.com
Thu Dec 13 11:16:39 EST 2007
Hi Marco:
I think is a good idea, but how could we deal with databases that don´t use schemas
like mysql? maybe in this case we could place all tables into public schema.
I have made several changes to this dialog and I have planned some others
I can move your changes later into ogr-plugin-branch after I have finished
with dialog design.
Regards
Godofredo Contreras
> Date: Thu, 13 Dec 2007 16:23:01 +0100
> From: marco.hugentobler at karto.baug.ethz.ch
> To: qgis-developer at lists.qgis.org
> Subject: [Qgis-developer] extensions to postgis dialog
> Hi,
> The list of tables in the postgis connection dialog may become quite long for users that have a lot of tables and views. I therefore would like the following extensions:
> -Convert the table widget to a tree widget. For every schema, there would an item that can be expanded/collapsed and contains the tables/views of the schema. Like this, there will be much better overview in situations with many schemas/tables/views.
> -Add a line edit that takes regular expressions and, if not empty, displays only the entries where the table name matches the regular expression.
> Are there any objections or suggestions to this?
> Godofredo, does this fit together with the work you are doing in the ogr-plugin-branch and shall I code the dialog extensions also into this branch?
> Regards,
> Marco
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
_________________________________________________________________
Share life as it happens with the new Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_122007
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20071213/3a230394/attachment.html
