[Qgis-developer] extensions to postgis dialog
Tim Sutton
tim at linfiniti.com
Thu Dec 13 12:44:16 EST 2007
Hi Godofredo
One thing I meant to comment about your API proposal was just a
pedantic issue. The QGIS coding style guidelines follow those of Qt
i.e. not using 'get' prefix for accessors. Also normally class names
should not contain abbreviations so QgsConnectionParams would become
QgsConnectionParameters. I know much of the code in QGIS doesnt follow
our own standards ( that will change eventually I hope ) but it is
good to ensure any new stuff does adhere to it to reduce overhead of
getting all the code standards compliant later.
Best regards
Tim
2007/12/13, godofredo contreras <frdcn at hotmail.com>:
> Hi Marco:
> I think is a good idea, but how could we deal with databases that don´t use
> schemas
> like mysql? maybe in this case we could place all tables into public schema.
> I have made several changes to this dialog and I have planned some others
> I can move your changes later into ogr-plugin-branch after I have finished
> with dialog design.
> Regards
> Godofredo Contreras
> ________________________________
> > Date: Thu, 13 Dec 2007 16:23:01 +0100
> > From: marco.hugentobler at karto.baug.ethz.ch
> > To: qgis-developer at lists.qgis.org
> > Subject: [Qgis-developer] extensions to postgis dialog
> > Hi,
> > The list of tables in the postgis connection dialog may become quite long
> for users that have a lot of tables and views. I therefore would like the
> following extensions:
> > -Convert the table widget to a tree widget. For every schema, there would
> an item that can be expanded/collapsed and contains the tables/views of the
> schema. Like this, there will be much better overview in situations with
> many schemas/tables/views.
> > -Add a line edit that takes regular expressions and, if not empty,
> displays only the entries where the table name matches the regular
> expression.
> > Are there any objections or suggestions to this?
> > Godofredo, does this fit together with the work you are doing in the
> ogr-plugin-branch and shall I code the dialog extensions also into this
> branch?
> > Regards,
> > Marco
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Share life as it happens with the new Windows Live. Share now!
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
