[Qgis-developer] qgis-svn and osx
massimo di stefano
massimodisasha at yahoo.it
Wed Dec 26 09:17:33 EST 2007
i'm on osx 10.4.11
building qgis from source on osx as well on linux
i have somme issue on the osx side :
- the msexport do not works (it isn't recognized by python)
log : " ms_export python module not found "
- the svn checkout is possible only exporting the utf.de environment :
export LC_CTYPE=de_DE.UTF-8
(maybe add these note on the wiki page is a good thing)
- in the grass-tools any script that use proj (like m.proj, that is
a front end to cs2cs)
do not works, the log give me :
proj not found please install it (you can test it in the
bash shall using m.proj comand)
(i already have proj and it is exported in my bash profile,
all commands works fine by command line)
-- as proj libraries i'm using the frameworks ,
i also tried to compile proj form source and modify the
qgis cmake setting ,
but nothing changes (on linux all works fine).
regards,
Massimo.
