[Qgis-developer] Adding custom fill styles?
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Wed May 16 02:55:09 EDT 2007
Hi Steven,
Custom fill styles would be a nice enhancement for QGIS!
> I'm
> wondering if it would be possible to create custom styles using
> QBrush::setTexture().
Yes, that's the way to go.
It is better to use QBrush::setTextureImage() function instead of the pixmap
one. In qgis core lib, we avoid using QPixmap. QPixmap needs a running
X-Server and is a problem for server applications using qgis lib.
> How difficult would this be to implement?
I think that most work to be done will be gui related.
> and someone can help get me pointed in the right direction.
The symbology (QPen, QBrush and possibly image for point symbols) is stored in
QGIS inside the class QgsSymbol.
The renderer classes (e.g. QgsSingleSymbolRenderer,
QgsGraduatedSymbolRenderer, etc.) contain one or more QgsSymbols, together
with the information which symbol to apply for which attribute value. If
QgsVectorLayer draws a feature, it passes the feature to a subclass of
QgsRenderer first and the renderer class sets the pen and brush (and possibly
the image) according to the attribute value of the feature. The vector layer
then draws the feature without having anything to know about the feature
symbology.
Important is the class QgsSingleSymbolDialog. This class is used to enter the
settings for a QgsSymbol. It is used also by QgsGraduatedSymbolDialog and
QgsUniqueValueDialog. It creates the settings for a QgsSymbol according to
user input. And I think QgsSingleSymbolDialog::apply(QgsSymbol*) is the
place, where the QImage for a custom fill style should be passed to
QgsSymbol. QgsSymbol then calls setTextureImage() for its brush.
QgsSingleSymbol could provide also the gui for a user to choose an image (or
a button that gives access to that gui).
>Is this what "
> qgsfillstylewidget.cpp" was meant for?
qgsfillstylewidget.cpp is legacy code. There was a discussion once about
having different gui for vector symbolisation, and I think this widget was
meant to be part of it.
If you have further questions, don't hesitate to ask. Also, it would be good
if you communicate from time to time your progresses, ideas, etc. on the
devel mailing list.
I would very much appreciate your contribution. For QGIS, it is always a
problem that we do not have enough developers regarding the amount of code in
the project.
All the best,
Marco
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
