[Qgis-developer] Building with msys.zip Qt-4.3.0-mingw
Bison-2.1 and Flex-2.5.4a-1
Jürgen E. Fischer
jef at norbit.de
Thu Nov 29 04:38:55 EST 2007
Hi Tait,
On Thu, 29. Nov 2007 at 09:30:22 -0000, Tait, Roger wrote:
> [ 10%] Generating qgssearchstringparser.cpp
> C:\Program Files\GnuWin32\bin\bison.exe: m4: No such file or directory
> mingw32-make[2]: *** [src/core/qgssearchstringparser.cpp] Error 1
> mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> mingw32-make: *** [all] Error 2
> C:\dev\cpp\qgis\build>
m4.exe should be also be in C:\Program Files\GnuWin32\bin, but bison
doesn't find it. Do you have in C:\Program Files\GnuWin32\bin in your
PATH?
However 3.3 from INSTALL suggests that you don't need GnuWin32's bison
as the msys image already has a bison.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
