[Qgis-developer] Building with msys.zip Qt-4.3.0-mingw Bison-2.1 and Flex-2.5.4a-1
Tim Sutton tim at linfiniti.com
Thu Nov 29 05:01:17 EST 2007
Hi
I think the c:\msys\mingw\bin dir or similar may be missing from your
path? Can you search for the bison exe under your c:\msys dir? I would
be grateful to receive any updates to the documentation should you
find it lacking anywhere...
Regards
Tim
2007/11/29, Jürgen E. Fischer <jef at norbit.de>:
> Hi Tait,
> On Thu, 29. Nov 2007 at 09:30:22 -0000, Tait, Roger wrote:
> > [ 10%] Generating qgssearchstringparser.cpp
> > C:\Program Files\GnuWin32\bin\bison.exe: m4: No such file or directory
> > mingw32-make[2]: *** [src/core/qgssearchstringparser.cpp] Error 1
> > mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> > mingw32-make: *** [all] Error 2
> > C:\dev\cpp\qgis\build>
> m4.exe should be also be in C:\Program Files\GnuWin32\bin, but bison
> doesn't find it.  Do you have in C:\Program Files\GnuWin32\bin in your
> PATH?
> However 3.3 from INSTALL suggests that you don't need GnuWin32's bison
> as the msys image already has a bison.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
