[Qgis-developer] Geoprocessing error
Carlos Dávila
cdavilam at jemila.jazztel.es
Fri Apr 11 13:57:24 EDT 2008
John C. Tull escribió:
> Horst,
> I tried performing a union of two vector files with multiple polygons,
> and received the error below. This was using the 0.35 version of the
> plugin with William Kyngesburye's RC1 binary of qgis (I still cannot
> get the plugin to work for me in my development builds). The union
> worked in ubuntu with version 0.35 of the plugin and latest svn.
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "/Users/jctull/.qgis//python/plugins/geoprocessing/geoprocessing.py",
> line 242, in geoprocessing
> self.union(myLayerA, myLayerB, myPath, myBool)
> File
> line 266, in union
> resultList = self.makeUnion(vlayerA, vlayerB)
> File
> line 832, in makeUnion
> unionResult = self.makeIntersection(vlayerA, vlayerB)
> File
> line 998, in makeIntersection
> fet.setAttributeMap(mAttributes)
> AttributeError: setAttributeMap
I'm getting a similar error with buffer or difference tools:
File "/C/Mis
documentos/.qgis//python/plugins/geoprocessing/geoprocessing.py", line
233, in geoprocessing
self.buffering(myLayerA, myParam, myPath, myBool, mergeBool)
File "/C/Mis
448, in buffering
vlayer = self.getVectorLayerByName(myLayer)
File "/C/Mis
516, in getVectorLayerByName
vlayer = QgsVectorLayer(unicode(layer.source(),'latin1'),
unicode(myName,'latin1'), providerName)
UnboundLocalError: local variable 'providerName' referenced before
assignment
System is debian testing, qgis r8328, Qt 4.3.3 and plugin v0.35. I think
error can be related with the layers being in edition mode, but I can't
reproduce error in another computer (the only difference is Qt 4.3.4).
Before the error a dialog entitled "Meldung" appears with the message
"Kein Provider gefundel!" (Shouldn't it be translated?).
Apart from this issue, I would like to suggest a couple of things:
1) The plugin has a "Save as:" box where you select a directory to save
the new layer. As you don't select a name but a directory, wouldn't it
be better to say "Save to:"?
2) Could output layer name for buffers be input_layer_bufferX.shp
instead of bufferX?
Regards and thanks for so useful plugin.
Carlos
