[Qgis-developer] About qgis menu item on OS X
John C. Tull
john.tull at wildnevada.org
Tue Dec 30 13:52:57 EST 2008
For some reason, when you click on 'About QGIS' from the application
menu in OS X (the menu item labeled 'QGIS'), you get a dialog on
Carson Farmer's ftools package if it is installed. If you go to the
Help menu and click About, you get the correct dialog that should also
be mapped to the application menu 'About QGIS' item. I suspect there
should be a separate item under the Tools menu for ftools.
When ftools is removed, the dialog is greyed out until you restart the
application. After restarting the application without ftools, the
'About QGIS' item brings up the correct dialog.
John
