[Qgis-developer] QGIS Building Error
Aaron Racicot
aaronr at z-pulley.com
Mon Jan 28 19:19:04 EST 2008
Marco,
Sorry I am not more help. On win I use the pre-built msys environments that
others with more inspiration than I have built. I know that the one I use
is built with the 2.X geos series. I have confirmed that the settings for
GEOS_INCLUDE_DIR and GEOS_LIBRARY are the same as what I have on my system.
But again, the version of geos that those point to was built by someone
else.
As far as the 3.x version of geos, I am using it quite successfully on my
linux based installs but have not tried on Win. Maybe someone with more
windows knowledge will step in and shed some light.
A
Aaron Racicot - GIS Programmer
360.221.2441 - aaronr at z-pulley.com
z - p u l l e y
pobox 1614
langley wa 98260
www.reprojected.com
> -----Original Message-----
> From: Marco Pasetti [mailto:marco.pasetti at alice.it]
> Sent: Monday, January 28, 2008 4:13 PM
> To: 'Aaron Racicot'; QGIS Developer Mailing List
> Subject: R: [Qgis-developer] QGIS Building Error
> mhh... Actually I don't know if they are "sane"; In advanced mode I have
> about GEOS:
> GEOS_INCLUDE_DIR = c:/msys/local/include
> GEOS_LIBRARY = c:/msys/local/lib/libgeos.dll.a
> Correct CMakesetup configuration is actually a great problem for me; I
> posted about it some hours ago, and there are no instructions in the wiki
> (excluding few and not very useful ones in
> http://wiki.qgis.org/qgiswiki/Building_with_CMake#head-
> 379089283e60811546c00
> e9cb0fffd8d75cc9739)
> Regards,
> Marco
> -----Messaggio originale-----
> Da: Aaron Racicot [mailto:aaronr at z-pulley.com]
> Inviato: martedì 29 gennaio 2008 1.04
> A: 'Marco Pasetti'; 'QGIS Developer Mailing List'
> Oggetto: RE: [Qgis-developer] QGIS Building Error
> Does CMake (i.e. ccmake) find your geos install? When you switch to
> advanced mode in ccmake can you verify all "geos" related vars have sane
> values?
> A
> z - p u l l e y
> pobox 1614
> langley wa 98260
> www.reprojected.com
> > From: qgis-developer-bounces at lists.qgis.org [mailto:qgis-developer-
> > bounces at lists.qgis.org] On Behalf Of Marco Pasetti
> > Sent: Monday, January 28, 2008 3:58 PM
> > To: QGIS Developer Mailing List
> > Subject: [Qgis-developer] QGIS Building Error
> > Hi,
> > I reported erros building qgis (0.9.1). It reports:
> > undefined reference to `geos::io::WKTReader::~WKTReader()
> > undefined reference to `geos::geom::Coordinate::~Coordinate()
> > Attached the whole error list (txt).
> > I created my own MSYS enviroment using GEOS 3.0.0 source code; should
> > I use
> > 2.2.3 instead? In this case, can I only re-build GEOS using 2.2.3
> > source code, or do I need to repeat all the instructions in the wiki
> after
> GEOS?
> > Thanks,
> > Marco
