[Qgis-developer] Update of release candidate 1 for project file
upgrade
Magnus Homann
magnus at homann.se
Tue Jan 29 12:24:02 EST 2008
Hello,
Due to a misunderstanding, the version string for 0.9.2-rc1-Ganymede had
a small error, making it impossible to do reliable revison upgrade of
the project files.
The version string is written into project files, and it is compared to
the running version of QGIS when reading projects. Depending on the
version, some transformation takes place. The version string should have
a format of "a.b.c-text", where only the integers a, b and c are
involved in the revision comparisons.
The version string that I checked in one hour ago should work much
better. I would appreciate if as many as possible could re-build
packages, minimiznig problems in the future.
Thanks,
Magnus Homann
