[Qgis-developer] qgspostgresprovider cursor bug and patch
    Stefanie Tellex
    stefie10 at media.mit.edu
    Tue Jan 29 17:20:00 EST 2008
I'm not sure the best place to post this, so apologies if this isn't the
right forum.  I found and fixed a bug in QgsPostgresProvider.  The bug
occurs when you make two providers that access the same table, and then
try to iterate through the features in each provider in a nested loop.
The provider in the inner loop would never have any features because all
providers use the same cursor name so things would get messed up.
I fixed the bug by adding a providerId member to QgsPostgresProvider,
and appending the id to all cursor names.  The patch is attached,
against version 8091 of https://svn.qgis.org/repos/qgis/trunk/qgis.
Stefanie
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080129/e878740d/qgspostgresprovider_ids_r8091.bin
