[Qgis-developer] Wrong Distance and Area measure values (Attempt 2)
Düster Horst
Horst.Duester at bd.so.ch
Thu Jul 3 03:14:25 EDT 2008
Ooops! Please excuse the prior mail. It seems that I made a mistake :-((
The distance and area measure function do not give correct measure
values. The values are totally different to the real values. The project
properties are defined correct. Under Settings/Project
Properties/Projection the check box 'Enable on the fly projection' is
checked and a correct EPSG Code (21781) is selected. Under
Settings/Project Properties/General the Map Units are set to Meters.
QGIS compiled from Composer-Branch works fine.
My System:
QGIS: r8705
QT4.3.4
Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080703/1079983f/attachment.html
