[Qgis-developer] Re: Last thing before branching Metis
Maciej Sieczka
tutey at o2.pl
Sat Jul 12 04:50:17 EDT 2008
Tim Sutton pisze:
> - Maciej can you test my solution for #1141? I'll probably just
> commit my change if I dont hear from you since I dont think it should
> cause any side effects.
It brings bug #1120 back (SRS k parameter always set to 0)!
https://trac.osgeo.org/qgis/ticket/1120
Not having #1141 fixed is as bad too.
> Many thanks all, I'll post an announcement tonight once I have
> branched.
Thanks for all your hard work too! However, I don't think QGIS should be
relaesed in it's current state, yet, given bugs #1120 and #1141.
Regressions are the worst kind of bugs. The regression in support for
non-US characters in GRASS will repel folks from using QGIS-GRASS
integration.
There is still also an outstanding bug in map composer - removing an
item in the map composer is not saved in the project:
http://trac.osgeo.org/qgis/ticket/924
Maciek
Maciej Sieczka
www.sieczka.org
