[Qgis-developer] map display problem.
Saravanan Ponnuswamy psaravanan81 at gmail.com
Fri Jul 18 00:30:18 EDT 2008
Hi everyone,
                    i have compiled and installed Qgis on SUSE 10.3. i
compiled a simple QGIS application given in the following website:
http://blog.qgis.org/?q=node/10. The application got compiled,but when i
run,the map is not getting displayed. i have another system with SUSE
10.1,and also i had compiled and installed ,qgis. there teh same application
opens successfully and map is displayed. i checked the gcc version of the
two versions and found that 10.1 contains 4.1.0-25 and 10.3 contains
4.2.0.will this be the cause for the map not being displayed.
Has anyone faced this kind of problem before ? if so can you suggest me the
solution for this ?
with regards,
saravanan.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080718/580e07d3/attachment.html
