[Qgis-developer] Re: Qgis app bundle script
John C. Tull
john.tull at wildnevada.org
Thu Jun 19 19:25:42 EDT 2008
So, the million-dollar question is how do you "fix" the core.so and
gui.so files? Is there a command line, series of steps, or edit that
you can share?
Thanks,
John
On Jun 19, 2008, at 3:17 PM, William Kyngesburye wrote:
> (back to the list to get others in on the discussion)
> Once I got the right geoprocessing plugin installed (not the builtin
> pggeoprocessing), I could test this. Indeed, in an unmodified build
> the Qgis Python console starts, but in the geoprocessing plugin, no
> layers are available to choose, even when there are layers in the
> layout.
> I then changed one thing: I "fixed" the library paths in core.so and
> gui.so to use the @executable_path relative path (fixing the source
> path as installed, and instead of the @loader_path that I use in my
> builds). Then it worked, I successfully created a buffer.
> This is with both a Leopard build on Leopard, using the system
> Python 2.5, and a Tiger build on Tiger, suing the python.org python
> 2.5.
> But, what about the all-in-one Qgis build? It has @executable_path
> in core.so and gui.so. I wonder if it's a Python version problem -
> the all-in-one Qgis is built to use the Tiger system Python 2.3, not
> the python.org Python 2.5. Though the Qgis python console starts,
> maybe the plugins need a more recent Python?
> While the Python 2.5 in the Leopard system is a very usable build of
> Python, Apple's Python 2.3 in Tiger is generally regarded as
> unusable for anything serious. Maybe the all-in-one build whould at
> least have one external requirement: Python 2.5?
> On Jun 18, 2008, at 10:17 PM, John C. Tull wrote:
>> Thanks again, William. I'll look forward to hearing your results
>> and input.
>> John
>> On Jun 18, 2008, at 8:03 PM, William Kyngesburye wrote:
>>> I've only tried one python plugin so far - manageR, back in May.
>>> I'll take a look at others and try one in a 'raw' build and see
>>> what I get.
>>> PS. Tim - are there plans to move Qgis python plugins out of
>>> ~/.qgis (for OSX)? Maybe ~/Library/Application Support/Qgis? I
>>> also have an old 'qgis.db' file in ~/.qgis from 2006, but I don't
>>> know if it's used any more.
>>> On Jun 18, 2008, at 9:56 PM, John C. Tull wrote:
>>>> William,
>>>> Just getting to today's email...
>>>> The problem is not with getting Python bindings or the console
>>>> working, instead it is with various plugins that attempt to query
>>>> layers from the map canvas. When I install the geoprocessing
>>>> plugin with your 0.10 build, I get a functional plugin that loads
>>>> layers in the drop-down menu list. For my builds, this does not
>>>> populate, so the python plugins are useless.
>>>> It must have something to do with your linking repairs post-
>>>> build. I would assume a script to run those changes that works
>>>> for anyone using your frameworks to build qgis from source would
>>>> end up with a binary that functions properly wrt python plugins.
>>>> Thanks,
>>>> John
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
