Fwd: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
Tim Sutton tim at linfiniti.com
Mon May 26 17:08:11 EDT 2008
Hi Tom
2008/5/23 Tom Elwertowski <telwertowski at comcast.net>:
> Tim Sutton wrote:
>> I'd like to put in a +1 for Tom to go ahead an apply this patch so we
>> can have it in QGIS 0.11.0 and then get rid of the final qt3 bits in
>> time for the next release (1.0).
> As the thread indicates, the patch was applied about two weeks ago. It's
> probably a good sign if you haven't noticed ;-) since the patch isn't
Oh we are always behind the times here in Brasil :-) Really I dont
know where my brain is these days :-( Thanks for the update...
Regards
Tim
> supposed to change functionality.
> However, I'll take advantage of this message to provide an update on the
> remaining Qt3 code removal.
> I just got the GRASS provider/plugin to compile without Q3Support. There are
> still many runtime issues so a patch for others to try is perhaps two weeks
> away.
> I also discovered that when QT_USE_QT3SUPPORT is removed from the top level
> CMakeLists.txt, the macro QT3_SUPPORT is no longer defined and we lose
> access to inline definitions which map old Qt3 method names to new Qt4
> method names, for example QString::find is now QString::indexOf. Sometimes
> in the next few days, I will be submitting a patch updating method names
> throughout qgis.
> A final note is that the GRASS plugin will not work using Qt-Mac-Cocoa
> simply by porting it to Qt4. There are symbol collisions between GRASS
> Vector and Mac libraries which do not happen in Qt-Mac-Carbon(4.4). The
> solution appears to be a partitioning of the GRASS plugin into Core and Gui
> layers so that GRASS Vector headers and QtGui headers do not appear in the
> same qgis files. This will be investigated after the complete port to Qt4.
> Tom
>>>>  Am Mittwoch 07 Mai 2008 08:46:18 schrieb Tom Elwertowski:
>>>>  > I merged your revision and submitted the patch.
>>>>  > Marco Hugentobler wrote:
>>>>  > > I think I found the reason for the problem with the ctrl - key.
>>>>  > > Once you changed this, please commit the patch to svn.
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
