[Qgis-developer] QGIS Python support in a library
John C. Tull john.tull at wildnevada.org
Thu May 29 11:08:20 EDT 2008
Thanks Martin. I'll look forward to the Mac dev gurus slogging through
this one. I think your plan to move python support to a lib is a great
idea, btw, so this will be worth the current hiccups.
Regards,
John
On May 29, 2008, at 4:40 AM, Martin Dobias wrote:
> On Thu, May 29, 2008 at 2:40 AM, John C. Tull <john.tull at wildnevada.org
> > wrote:
>> On May 28, 2008, at 4:28 PM, Martin Dobias wrote:
>>> If you build debug version, at some stage during initialization it
>>> shows information about success / failure of loading the qgispython
>>> library and initializing python. Could you check what does it say?
>>> Martin
>> This is reported:
>> 5/28/08 5:38:10 PM [0x0-0x4d04d].org.qgis.qgis[7306] Debug:
>> /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 385: (QgisApp)
>> Couldn't load Python support library.
> Ah so when it's already about loading problems of the library I can't
> be of much help here - hopefully William or Tom will find out what's
> wrong. I suspect there might be problem with ADD_LIBRARY flags in
> src/python/CMakeLists.txt. Another point where to take care is that
> the qgispython library is loaded with additional flags specified for
> QLibrary to force that all symbols from python lib are exported,
> otherwise python's not working, see this thread (I had the same
> issue):
> http://lists.kde.org/?l=pykde&m=117190116820758&w=2
> Martin
