Friday 30 of May 2008 14:32:10 Düster Horst napisał(a): > The major change to Carsons approach, I took QtXML to read the repsository > XML due to segmentation faults of minidom on my system. I don't know the > reason!! Do you have the same faults in the Plugin Installer? As far I remember, Carson has used its code.
