[Qgis-developer] Re: ideas for developpers)
Tim Sutton tim at linfiniti.com
Fri May 30 23:26:58 EDT 2008
Hi
> I was writing about makeshift free moving the plugin items inside
> the menus
> and toolboxes, but now it's not so important, since Carson has
> promised to
> put all his plugins in order :DD
> Categorisation is not hard to implement technically, but it's much
> harder to
> elaborate good (clear and sufficient) categories :) I think we need
> the
> vision of future QGIS tools structure and fit all the plugins into
> it, but
> even ArcGIS doesn't bring me many good ideas. Maybe it's time for huge
> brainstorm. Then the category mechanism will be even unnecessary,
> if plugin
> developers swear to keep the rules ;)
After 1.0 goes out we will hold such a brainstorm and plan the vision
for generation 2.0 of QGIS and how we can adapt it to make it more
than a GIS viewer but rather a GIS with analytical capabilities. The
original idea for 1.0 was originally to buld a competent data browser.
> Sebastien Vial wrote:
>> - database oriented plugins
>> - raster oriented
>> - import/export
>> - selecting
>> - statistics...
> These ideas are good for a start.
Yes these seem like a good start.
>> * and about the plugin manager : adding a column to know the
>> installed
>> version of the plugin (like some linux package manager), in order to
>> compare the version number, and to know if the plugin needs to be
>> re-installed --- and perhaps a warning when there is a new version
>> of a
>> plugin
> I don't know C++ yet, so now I can improve Plugin Installer and add
> the
> features:
>  - the version column as you said
>  - the column with status indicator: upgradable/new in repository
>  - checking for updates and for news in repositories on demand and
> also
>    when QGIS is starting.
I prefer to move away from column style UI which I think is not so
friendly. To me it would be better to expand the detailed item
delegate I wrote for the C++ plugin manager to include a place next
to each plugin title to indicate if new versions are available. When
QGIS starts we should check background thread when qgis starts go off
and see if new plugins are available and give the user a 'soft
notification' (like an indicator on the status bar that when clicked
will open the manager and download updates).
> Someday this code might be attached to the Plugin Manager (when I
> learn C++!),
> but before 0.11 release I can implement this only in the Plugin
> installer.
> So what do you think about it? And what about removing the Plugin
> Installer
> item from the Plugins menu and launching it directly from the Manager?
> Tim, can you implement this and do you think it's suitable?
I would very much like to unite the C++ and python managers. As
Martin says the main issue is .zip extraction support in Qt, but Im
sure this can be resolved with a bit of googling.
Regards
Tim
> And one question. There are two branches in the QSettings:
>       Plugins/$PLUGIN_NAME        = bool
>       PythonPlugins/$PLUGIN_DIR   = bool
> What they mean? They don't correspond with actually enabled plugins
> at mine!
> Regards,
> B.
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
