[Qgis-developer] Mac Xcode config changes
John C. Tull john.tull at wildnevada.org
Wed Apr 15 23:04:35 EDT 2009
William,
I'm back to testing your Xcode project. I agree with other folks that
this is a great and valuable addition to qgis.
Using the stock template on my 10.5 machine with your frameworks and
nothing else non-stock, plus qt-4.5 (not 4.4), I have run into a
couple of problems.
For some reason, an include in qgspythonutilsimpl.cpp is not getting
picked up:
#include <Python.h>
fails to be found. If I add the full path to Python.h as:
#include </System/Library/Frameworks/Python.framework/Versions/2.5/
include/python2.5/Python.h>
I run into a new error:
/Users/jctull/sources/qgis/trunk/mac/xcode/build/native/Qgis.build/
Release/python_modules.build/Script-7256F1530F4105770022BE1F.sh: line
40: /Library/Frameworks/Python.framework/Versions/2.5/bin/python: No
such file or directory
I'm unclear as to why it is looking in /Library... when it should be /
System/Library...
That is the state of things for me right now.
Regards,
John
On Apr 13, 2009, at 6:22 AM, William Kyngesburye wrote:
> To all Mac users (of the Xcode project): I made some changes to the
> Xcode configuration, so it would be a good idea for you to check
> your qgis_user.xcconfig with the template (and clean).
> There may be more changes to the template coming up, but I think I
> did everything I need - I'm working on a way for the cmake
> configuration to generate a gqis_user.xcconfig (handy for the casual
> user).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
> Qgis-developer mailing list
