Fwd: [Qgis-developer] Help needed in creating Third Level Submenu
Germán Carrillo
carrillo.german at gmail.com
Tue Aug 4 15:30:39 EDT 2009
Bishwarup, you can use addActions in your self.DM object because it is an
instance of QMenu, which inherits from QWidget. While your self.Div1 is an
instance of QAction which doesn't inherits from QWidget, so self.Div1 can't
access to addActions method.
Take a look at this: http://doc.qtsoftware.com/4.5/classes.html
Germán
El 4 de agosto de 2009 00:14, Bishwarup Banerjee <
bishwarup.banerjee at gmail.com> escribió:
Hi German,
> Thank you very much for your reply. I will try to incorporate the way you
> suggested. But, I thing I was wondering is that if "addActions" does not
> inherits from QAction, then how is that when I go to only second level of
> submenu option, instead of thrird level, it works fine. The problem arises
> only when we go to the third level.
> With warm Regards,
> Bishwarup
> 2009/8/3 Germán Carrillo <carrillo.german at gmail.com>
> Hi Bishwarup, the addActions method is in QWidget class, and QAction don't
>> inherited from that. So addActions don't exist for QAction. Maybe you can
>> use QtDesigner to create the menu level you want and then generate the .py
>> with pyuirc4, this way you can see how to create it.
>> Why you don't use the last QGis version?
>> Germán
>> 2009/8/3 Bishwarup Banerjee <bishwarup.banerjee at gmail.com>
>>> Dear All,
>>> I am trying to create THIRD LEVEL MENU through the following code. Like
>>> I have a menu Called "Boundaries", inside that I have sub menu called
>>> "Division", inside that I have "Division_name", inside "Division Name" we
>>> have a separate sub menu called "Division Range", on clicking on the sub
>>> menu "Division range" some action is done, like opening the range boundary
>>> shape file. I am able to open the Shape file portion, but I am getting error
>>> in the Bold Line marked as "AttributeError: addActions"
>>> self.menu = QMenu()
>>> self.menu.setTitle( "Boundaries" )
>>> self.DM = QMenu( "Division" )
>>> self.Div1 = QAction( QIcon( ":/icons/find.png" ), "Division
>>> Name",self.iface.getMainWindow() )
>>> self.DM.addActions( [ self.Div1])
>>> self.menu.addMenu( self.DM )
>>> menuBar = self.iface.getMainWindow().menuBar()
>>> menuBar.addMenu(self.menu)
>>> self.Div_Range = QAction( QIcon( ":/icons/find.png" ), "Division
>>> Range",self.iface.getMainWindow() )
>>> *self.Div1.addActions( [ self.Div_Range])*
>>> self.menu.addMenu( self.Div_Range )
>>> QObject.connect( self.Div_Range, SIGNAL("triggered()"),
>>> self.Div1_Clicked )
>>> It will be of immense help, if anybody can point the error in the code,
>>> or is it like THIRD LEVEL SUBMENU is not supported in QGIS?
>>> I am using QGIS 0.11, Python 2.5 and QT.
>>> I am posting the same in the QGIS Developer forum
>>> Thanking you in advance,
>>> With Warm Regards
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> |\__
>> (:>__)(
>> Soluciones Geoinformáticas Libres
>> http://geotux.tuxfamily.org/
|\__
(:>__)(
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090804/620e2e70/attachment-0001.html
