[Qgis-developer] Xcode project in qgis svn
John C. Tull
john.tull at wildnevada.org
Mon Feb 16 22:39:01 EST 2009
On Feb 16, 2009, at 6:43 PM, William Kyngesburye wrote:
> On Feb 16, 2009, at 8:30 PM, John C. Tull wrote:
>> Gary,
>> If this gets added to svn, would you be willing to help detail the
>> build instructions. I gave it a quick attempt yesterday, but gave
>> up due to my lack of familiarity with XCode (I'm also using a newer
>> version: 3.1.1). The developer instructions are useful, but seem to
>> anticipate a level of experience with Apple's dev environment than
>> many of us probably possess. It sounds like you were able to break
>> through on that.
> Yeah, random notes in the developer readme. needs much work.
Now that I'm not rushing as much, I seem to be making some progress.
If I can sort this out, I will try to take a stab at more detail. You
forget how much less than you we know about this stuff. ;-)
> I suppose I'm a bit terse in the main readme... that's mostly from
> the original readme when I played around with Xcode a couple years
> ago. At the time I guess I was assuming Xcode familiarity.
> Suggestions for user-friendliness welcome. One idea just occurred
> to me - a shell script to generate qgis_user.xcconfig. I can use
> stuff from my build scripts for my frameworks. Accepting defaults
> would really just make an empty file (Xcode complains if it's
> missing). I should be able to get the different levels of
> configuration handled in a friendly way (those levels were meant to
> be friendly themselves, but require manual editing right now).
The main problem is sorting out silly things like how to properly add
a source as a relative project to the Xcode project. I got past that
one, but I'm not sure if the portion under "Adding core/gui/app moc
sources" is necessary or not. That's where I'm at right now.
Cheers,
John
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090216/ffe88d2c/attachment-0001.html
