[Qgis-developer] Xcode project in trunk
John C. Tull
john.tull at wildnevada.org
Mon Feb 23 22:21:19 EST 2009
William,
Will this work with Qt 4.5? I tried last week but hit some snags. I'm
not sure if there is a configuration setting to change, or if it is
more complicated than that.
Ok, now I've actually tried again to build using your latest svn code.
I was hoping to report the error I was having last week, but now I
have a ccache error cropping up repeatedly:
error: can't exec '/Developer/Library/Xcode/Plug-ins/GCC 4.0.xcplugin/
Contents/Resources/ccache gcc' (No such file or directory)
Any ideas on how to circumvent this problem?
Thanks,
John
On Feb 23, 2009, at 5:33 PM, William Kyngesburye wrote:
> For those that didn't notice, I added the OSX Xcode project to trunk
> this weekend. Build works. Needs work on developer docs, for
> project maintenance. I'll work on making the build docs easier to
> understand, and simplifying parts of the configuration.
> It's in a "v2.4 compatible" format, so it should theoretically work
> on Xcode 2.4. This makes Tiger (OSX 10.4) the minimum for building
> Qgis from the project (but Qt 4.4 requires gcc 4 to build on OSX, so
> Panther's not an option anyways, unless you're very adventurous).
> I'll test Xcode 2.5 when I get a chance.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is
> an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
> Qgis-developer mailing list
