[Qgis-developer] Xcode project in trunk
William Kyngesburye
woklist at kyngchaos.com
Mon Feb 23 22:57:07 EST 2009
On Feb 23, 2009, at 9:21 PM, John C. Tull wrote:
> William,
> Will this work with Qt 4.5? I tried last week but hit some snags.
> I'm not sure if there is a configuration setting to change, or if it
> is more complicated than that.
I don't know about Qt 4.5 compatibility with Qgis. I haven't tried
it, so I can't say if there are some subtle installation changes in Qt
4.5 that would cause problems in the project. A quick pre-install
look at Qt 4.5 shows a couple new frameworks, maybe there's some new
inter-linking going on?
> Ok, now I've actually tried again to build using your latest svn
> code. I was hoping to report the error I was having last week, but
> now I have a ccache error cropping up repeatedly:
> error: can't exec '/Developer/Library/Xcode/Plug-ins/GCC
> 4.0.xcplugin/Contents/Resources/ccache gcc' (No such file or
> directory)
> Any ideas on how to circumvent this problem?
Sounds like something seriously wrong with your Xcode installation. I
don't have a "ccache" in my installation, so something is mistakenly
trying to find it there. In fact, I can't find a ccache anywhere on my
drive. Which target is the error in?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
