[Qgis-developer] printing with qgis
Florian Lohoff
flo at rfc822.org
Mon Jan 19 11:38:21 EST 2009
i started using qgis lately for my OSM work - I was trying to print
an arbitrary region for later survey. I found multiple annoyances while
printing.
1. WMS Server size limit. Its nice to display the warning that
overflowing the size constraints of a WMS server might cause the
data not to be printed.
It would be much nicer to show the warning when the requests fails
and inform the user that the print failed (it makes no sense to print
nothing)
A much better solution would be to halve the request size until
the size constraints are satisfied and stitch together the result.
2. PDF Printing - PDF Printing might be very convinient for the
developer but burdens the load on providing postscript to the
printserver. I only found out because of 3) and a very slow print
server (AMD K6 took hours to rip the pdf into postscript)
3. Buffered labels take ages to render in PDF and/or to print.
I havent looked at the buffered Labels more closely but as a matter
of fact some buffered labels cause my A4 print to take 3-4 hours
to render on a AMD K6 Cups printserver using pdftops. Turning
off buffered labels made the print nearly instantanious.
I could also reproduce this by saving a pdf and opening with
acroread. One could see acroread rendering the single label
one ofter another in a very slow way (Intel Core Duo)
This was all experienced with the debian packages:
qgis_1.0.0-gfossit20081222-2_i386.deb
As the crashes also were quite annoying i am now running RELEASE_1_0_0
svn branch to collect backtraces ;)
Flo
Florian Lohoff flo at rfc822.org +49-171-2280134
Those who would give up a little freedom to get a little
security shall soon have neither - Benjamin Franklin
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090119/b867a01c/attachment.bin
