AW: [Qgis-developer] advanced printing branch 2
John C. Tull john.tull at wildnevada.org
Sat Jan 24 12:38:56 EST 2009
It might be that they are, although I had not noticed. Once you merge
into trunk I will try again. Are you still planning that soon or
holding off?
John
On Jan 24, 2009, at 1:21 AM, Hugentobler Marco wrote:
> Hi John,
> Thanks for the hint. On Ubuntu, everything seems ok. As long as the
> main map window does not have focus, the shortcuts are not applied.
> Seems an OS X specific issue. I'm going to try it on OS X next week.
> Maybe also the other file dialogs used in QGIS are affected by this
> problem?
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: John C. Tull im Auftrag von John C. Tull
> Gesendet: Fr 23.01.2009 20:32
> An: Hugentobler  Marco
> Cc: qgis-developer
> Betreff: Re: [Qgis-developer] advanced printing branch 2
> Marco,
> Today, I noticed that there is at least one problem on OS X. When
> trying to save a composer template, the keyboard inputs are being read
> by qgis as shortcuts. I.e., typing a 'h' in a filename does not put an
> 'h' character in the dialog box but hides all the layers on the map.
> This is with your most current advanced printing branch code.
> Regards,
> John
> On Dec 24, 2008, at 5:57 AM, Marco Hugentobler wrote:
>> Dear qgis devs,
>> The advanced printing branch 2 is ready to be tested now that
>> feature freeze
>> is over. You can obtain the sources with:
>> svn co http://svn.osgeo.org/qgis/branches/advanced_printing_branch2
>> In the branch, there are some new features (all inside the print
>> composer):
>> - alignment of items
>> - snapping of items to a grid
>> - preview for svg images
>> - composer templates
>> Please report any issues you find with those new features. I'm going
>> to be in
>> vacations for some time and will adress them in the new year.
>> Merry christmas and happy new year,
>> Marco
>> Dr. Marco Hugentobler
>> Institute of Cartography
>> ETH Zurich
>> Technical Advisor QGIS Project Steering Committee
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
