AW: [Qgis-developer] advanced printing branch 2
John C. Tull
john.tull at wildnevada.org
Sat Jan 24 12:41:44 EST 2009
I see in the logs that you did the merge this morning. I'll build and
test that a bit.
Regards,
John
On Jan 24, 2009, at 9:38 AM, John C. Tull wrote:
> It might be that they are, although I had not noticed. Once you
> merge into trunk I will try again. Are you still planning that soon
> or holding off?
> John
> On Jan 24, 2009, at 1:21 AM, Hugentobler Marco wrote:
>> Hi John,
>> Thanks for the hint. On Ubuntu, everything seems ok. As long as the
>> main map window does not have focus, the shortcuts are not applied.
>> Seems an OS X specific issue. I'm going to try it on OS X next
>> week. Maybe also the other file dialogs used in QGIS are affected
>> by this problem?
>> Regards,
>> Marco
>> -----Ursprüngliche Nachricht-----
>> Von: John C. Tull im Auftrag von John C. Tull
>> Gesendet: Fr 23.01.2009 20:32
>> An: Hugentobler Marco
>> Cc: qgis-developer
>> Betreff: Re: [Qgis-developer] advanced printing branch 2
>> Marco,
>> Today, I noticed that there is at least one problem on OS X. When
>> trying to save a composer template, the keyboard inputs are being
>> read
>> by qgis as shortcuts. I.e., typing a 'h' in a filename does not put
>> an
>> 'h' character in the dialog box but hides all the layers on the map.
>> This is with your most current advanced printing branch code.
>> Regards,
>> John
>> On Dec 24, 2008, at 5:57 AM, Marco Hugentobler wrote:
>>> Dear qgis devs,
>>> The advanced printing branch 2 is ready to be tested now that
>>> feature freeze
>>> is over. You can obtain the sources with:
>>> svn co http://svn.osgeo.org/qgis/branches/advanced_printing_branch2
>>> In the branch, there are some new features (all inside the print
>>> composer):
>>> - alignment of items
>>> - snapping of items to a grid
>>> - preview for svg images
>>> - composer templates
>>> Please report any issues you find with those new features. I'm going
>>> to be in
>>> vacations for some time and will adress them in the new year.
>>> Merry christmas and happy new year,
>>> Marco
>>> Dr. Marco Hugentobler
>>> Institute of Cartography
>>> ETH Zurich
>>> Technical Advisor QGIS Project Steering Committee
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
