AW: [Qgis-developer] advanced printing branch 2
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Tue Jan 27 04:04:57 EST 2009
Hi John,
I tested on a G4 with OS 10.4 and Qt 4.4.1.
Everything seems ok with the template save dialog for me. As long as the save
dialog has focus, the shortcuts are not applied.
I don't know what the critical difference is between your installation and my
one. Maybe the OS X version, Intel/not Intel Mac or is it the Qt version?
Anyway, it would be good if other Mac user could test the behaviour of the
template save dialog on their system.
cheers,
Marco
Am Samstag 24 Januar 2009 18:41:44 schrieb John C. Tull:
> I see in the logs that you did the merge this morning. I'll build and
> test that a bit.
> Regards,
> John
> On Jan 24, 2009, at 9:38 AM, John C. Tull wrote:
> > It might be that they are, although I had not noticed. Once you
> > merge into trunk I will try again. Are you still planning that soon
> > or holding off?
> > John
> > On Jan 24, 2009, at 1:21 AM, Hugentobler Marco wrote:
> >> Hi John,
> >> Thanks for the hint. On Ubuntu, everything seems ok. As long as the
> >> main map window does not have focus, the shortcuts are not applied.
> >> Seems an OS X specific issue. I'm going to try it on OS X next
> >> week. Maybe also the other file dialogs used in QGIS are affected
> >> by this problem?
> >> Regards,
> >> Marco
> >> -----Ursprüngliche Nachricht-----
> >> Von: John C. Tull im Auftrag von John C. Tull
> >> Gesendet: Fr 23.01.2009 20:32
> >> An: Hugentobler  Marco
> >> Cc: qgis-developer
> >> Betreff: Re: [Qgis-developer] advanced printing branch 2
> >> Marco,
> >> Today, I noticed that there is at least one problem on OS X. When
> >> trying to save a composer template, the keyboard inputs are being
> >> read
> >> by qgis as shortcuts. I.e., typing a 'h' in a filename does not put
> >> an
> >> 'h' character in the dialog box but hides all the layers on the map.
> >> This is with your most current advanced printing branch code.
> >> Regards,
> >> John
> >> On Dec 24, 2008, at 5:57 AM, Marco Hugentobler wrote:
> >>> Dear qgis devs,
> >>> The advanced printing branch 2 is ready to be tested now that
> >>> feature freeze
> >>> is over. You can obtain the sources with:
> >>> svn co http://svn.osgeo.org/qgis/branches/advanced_printing_branch2
> >>> In the branch, there are some new features (all inside the print
> >>> composer):
> >>> - alignment of items
> >>> - snapping of items to a grid
> >>> - preview for svg images
> >>> - composer templates
> >>> Please report any issues you find with those new features. I'm going
> >>> to be in
> >>> vacations for some time and will adress them in the new year.
> >>> Merry christmas and happy new year,
> >>> Marco
> >>> Dr. Marco Hugentobler
> >>> Institute of Cartography
> >>> ETH Zurich
> >>> Technical Advisor QGIS Project Steering Committee
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
ETH Zurich
